Old 02-22-2010, 08:27 PM   #1
Default shower pressure low
Remodel shower and had plumber come in to put in shower control and lines (copper). After shower remodeled attached shower head and turned on, shower pressure very low. Removed shower head and with straight pipe (no shower head) the water came out in small stream (low pressure). I notice a set screw on on either side of the control valve with a lock nut, are these pressure regulators that are to be adjusted?
rick is offline   Reply With Quote
Old 02-22-2010, 11:27 PM   #2
Those sound like supply stop valves. Check to make sure that the center screw is backed all the way out on both sides, so as to allow full flow. As long as they aren't partially closed, they should have nothing to do with the pressure.
Old 02-22-2010, 11:53 PM   #3
Thanks you are right about supply stop valves. Still no pressure. there is a red plastic ring with a green tab over the valve stem held on by a copper C ring. I hesitate to remove it because the whole shower control might come apart. is this a normal thing on the shower valve stem?
Old 02-23-2010, 12:48 PM   #4
Expert Turd Herder
Reedwalker's Avatar
Pictures and Brand names will help here
Old 02-23-2010, 02:39 PM   #5
Originally Posted by rick View Post
had plumber come in to put in shower control and lines.....
Why don't you call the plumber back and make him fix the problem?
Water pressure, shower pressure
