Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Shower make over , needs ideas and help
Old 01-21-2014, 07:00 AM   #1
Jimfishon
Default Shower make over , needs ideas and help
Bare with me as my terminology is likely incorrect .
Iam having to replace a shower due to a shower pan and/or drain that gave way . Iam just starting and since this is a spare bathroom have decided to do a shower kit. Great news is i have crawl space to work under . The *kit* i have will require the shower drain be moved . So i'll start there so i can then get the flooring back down . After reading it appears my pipes are cast iron and i would like to change the shower pipe to pvc /abs since i have access to it now and have to replace the broken flange anyways.
I believe i'll need a fernco coupling but is there a better area i should cut the cast iron pipe at or an area to stay away from ? The existing drain centered at 12 inch out from the side wall and 15 inch from the back wall , so i do have to move it a decent amount .
Jimfishon is offline
Zanne Likes This
Old 01-22-2014, 01:39 AM   #2
Liked 384 Times on 324 Posts
Likes Given: 549
You should remove as much of the cast iron pipe as you can get to.
phishfood is online now
2
People Like This
Does this layout make sense JeffreyPWheeler General Plumbing Help 4 12-31-2013 11:37 AM
Toilet/Shower backup - out of ideas Nellspixia Drain and Sewer Cleaning 2 09-04-2011 02:30 PM
How to make trench refill look better? longbow General Plumbing Help 2 01-27-2011 05:14 AM
Terrazzo Shower Pan. I need Ideas. Wade Showers and Tubs 2 02-12-2010 06:02 AM
