Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Showers and Tubs > Shower knob screw stripped
Old 01-16-2011, 07:44 PM   #1
Default Shower knob screw stripped
If you pop the cap of my shower (cold water) knob, there is a little screw that holds the knob onto the cartridge/valve. I wanted to take the knob off and clean the inside of it. I'd say the screw is stripped. It was REAL hard to get started, and now it turns but doesn't back out. How can i get the knob off? There is a metal sleeve behind the knob that screws on, maybe unscrew that and it forces the knob off. Uh, I dunno.....
reepotomac is offline
Old 01-19-2011, 07:42 PM   #2
NotAnotherRep's Avatar
Is the cap you removed from the top of the handle or the side? If its on the top and you can see the screw and it turns but does not come off, then try gently pulling the handle off as you are undoing the screw. the screw is normally is attached to the brass spindle of the valve. If this does not work then it needs drilling out which may mean that you would have to replace the valve. hope this helps!!
NotAnotherRep is offline
nothing for replacement flange to screw to keithpf Toilets and Sinks 8 06-20-2011 04:34 AM
installing shower mixing valve and knob stevespens Showers and Tubs 2 02-03-2011 05:32 PM
Shower knob question Madhavok Showers and Tubs 2 02-02-2011 05:09 AM
Shower Knob Replacement ivinew Showers and Tubs 8 09-19-2010 04:24 AM
shower knob position incorrect crankbait09 Showers and Tubs 2 03-04-2010 11:06 PM
