Hi, I need to get a replacement for my shower knob but I can't seem to find info on it online. I looked on the plate and it says LM 104870 and the company is SA?
I believe it is just a local production number and probably not anything you would get a match from. I'd recommend you take off the handle and plate, and peruse the selection at Lowe's or Home Depot and physically match up a replacement.
I have exactly same plate with LM104870, I need to replace catridge and also looking for the brand name.
I think CSA is not brand name, it means certified pruduct in US and Canada.
Although I just went thru about 150 different valves from the Home Depot catalog, I was unable to locate it. I have seen this set up often in homes, and believe it is an older Price Pfister or Moen brand. Have you considered removing the handle and plate to see it you could match it up with a current one for sale?
I had a problem that had no cold water from same faucet. I took the catridge and fixed the problem. now it's working fine.
I tried to find it from all stores but, I could not find it.
You may try to fix it.
If you can take the handle off so that the cartridge is visible, and post another picture of that, it might help in identifying what brand of valve it is.
