Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Showers and Tubs > Shower Ground Strap
Old 06-02-2011, 05:49 PM   #1
Default Shower Ground Strap
I'm in the process of remodeling our bathroom and have removed the old galvanized pipe from the shower and have replaced it with copper. The copper is connected to the galvanized pipe under the house.
My Question:
There was a grounding wire connected to the galvanized pipe and I'm wondering what I should do with it.
Because I had to use a dialectic union to connect the galvanized pipe to the copper I'm not sure what pipe section to ground.
Should I...
1) Connect it to the copper pipe (does that defeat the purpose of the dialectic union?)
2) Connect it to the galvanized pipe under the house. (Will I get shock in the shower?)
Thanks,
Daniel
daniel75 is offline
Old 06-03-2011, 09:45 PM   #2
Journeyman
Take off the dielectric union and replace it with a brass nipple (6" is recommended). This will keep your ground and prevent corrosion at the same time.
joesplumbing is offline
