Plumbing Forum - Professional & DIY Plumbing Forum
Specific Plumbing Discussion
Showers and Tubs
Removing shower frame
User Name
Remember Me?
Password
Register
Plumbing Albums
FAQ
Members List
Search
Today's Posts
Mark Forums Read
LinkBack
01-06-2010, 05:42 AM
1
rick
I need to remove shower door frame from cultured marble walls, the frame is silliconed onto the marble. Any tricks to use that won't break the marbl?
01-06-2010, 05:47 AM
2
I would use a new, sharp razor blade, with some soap as a lubricant to avoid scratching the surface. Finish with a Goo Be Gone or similar product, but test before using to prevent staining.
01-06-2010, 04:22 PM
3
rick
been using razor with no luck, however your idea of a soap lubricant sounds good.
silicone
shower
frame
removal
Oatey and Ebbe drain
Add a basement shower
Show Printable Version
Email this Page
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
Off
Pingbacks
are
On
Refbacks
are
On
Forum Rules
Re-Circ pumps?
what is a transition fitting?
Custom Shower Design?
My new truck
"The official uniquely randomized designed thread"
Had septic tank pumped yesterday. Full again
Calcium in water lines
Pex Tubing Runs
Kohler Pompton series leaking water into the bowl
American Standard fresh air intake?
Content Relevant URLs by
vBSEO
3.6.0
Network:
Flooring Forum
Home DIY Forum
Garage Forum
Painting Forum
Contact Plumbing Forum
Privacy Statement
Terms of Service
Top
LinkBack
LinkBack URL
About LinkBacks
