That is a Moen PosiTemp.
Grab the top of the clip with a pair of pliers, and pull it straight up. Once that is out, grab the brass stem and pull it straight out. This can be pretty difficult. In fact, it is possible that you might have to get a cartridge puller to remove the old cartridge. Most plumbing supply houses should have those in stock.
When you put the replacemet cartridge in, make sure that you put it in right side up, or the hot and cold will be reversed.
Hope this helps.
