To improve the installation and simplify my question:
I would like the output of the P-trap on our new shower to be as close as possible to shower-pan level.
How small a drop is possible there?
(Clearly, the top of the outlet pipe must be below the pan. But I don't know if there are practical P-traps that allow it to be close, or if they all need a significant drop from pan to top of outlet. Every inch matters.)
Background: Shower is on existing slab. I'm reluctant to saw a slot through the slab for the entire drain line, given that this is inside an occupied house. (Heavy equipment, wheelbarrows of debris, wheelbarrows of cement.)
On the other hand, routing the drain line above the sill plate will give my shower pan a height above 6", which isn't great.
I'm hoping to compromise, by boring and chipping the cement only as much as needed to route the drain line just below the sill plate. At 9' of run with 2" line, this puts my shower pan height at 4-1/2" plus the pan-outlet gap.
Homeowner in WA
