Old 01-02-2012, 09:59 PM   #1
Default Older delta faucet leaks, help me identify it.
I have a very old bath/shower faucet that I can't get it to completely stop dripping, no matter what position I close it in. The best way to explain it is like a joystick. You push it up to turn it on, left to make it warmer, right to make it colder. It has what I would call a sheath that goes around all of the internals. I know if I can get it taken apart I can replace a gasket or something, but I have no idea what part number this faucet is.
pmreimer is offline   Reply With Quote
Old 01-02-2012, 10:18 PM   #2
Looks like a model 642. Call Delta @ 1‑800‑345‑DELTA (3358) to see if parts are still available. Some hardware stores may carry repair kits, but I believe that model is discontinued.
Old 01-02-2012, 10:38 PM   #3
It uses the same seats, springs and ball as the delta 400 kitchen faucet. Have you tried tightening the ring inside the retaining nut?
Old 01-03-2012, 03:16 PM   #4
Thanks to both of you. From what I can tell from Delta's site, the ring I think I should tighten is corroded to the point that I don't want to deal with it. I think I'd rather replace it at this point; it's had 30-40 years of use, I think, and wouldn't be up to any code... but how do i get it off?
Old 01-10-2012, 06:51 AM   #5
MASTER PLUMBER
DUNBAR PLUMBING's Avatar
Utilize the R10000 valve from Delta.
You'll have to remove it from the water lines, install a new one.
