Old 01-11-2012, 11:13 PM   #1
Default Old Gerber valve
I went to look at a leak this evening.
When I got there, I found a rather old 2 handle Gerber shower valve leaking aroung the handle, and supposedly, also leaking inside the wall down into the laundromat below. There was no way to shut off the individual room with the bad valve, so I would have had to shut off the laundromat and all of the other rooms to pull the valve apart, so no way for me to pull the cartridge to see what would be needed.
The owner doesn't want to spring for a new valve, so I am trying to find out what would be involved in rebuilding this one.
Did Gerber have a lot of different valves, or were they pretty much the same?
Obligatory picture of the handle:
Old 01-12-2012, 12:06 AM   #2
I may even have a stem on my truck for that.
No work today And I just got a call from the office telling me to sleep in.
I hate customers that want miracles but don't want to spend the money.
I just looked in a PartsMaster stem book and there are 15 different stems.
Old 01-12-2012, 12:27 AM   #3
Not what I wanted to hear, but thanks.
Here's hoping that they wake you up with 10 hours worth of work tomorrow.
Old 01-12-2012, 12:28 AM   #4
Plumbmaster,Inc catolag
The seat seem to be the same
Cat# 30027 or Ref # 90-161
and all the tub shower valve seem to all take the same stem assebly
Cat # 05079P or Ref #96-717
They are similar to PP valve stems and seats
http://www.faucetpartsplus.com
Old 01-12-2012, 12:59 AM   #5
Thanks for the part numbers. I will see if I can lay my hands on a set of stems and seats. Do the stems usually give trouble coming out?
Old 01-12-2012, 01:07 AM   #6
Just make sure you open the valve before you remove the stem. I've seen a few people drive the stem through the back of the valve like a screw jack and destroy a faucet or two.
Old 01-12-2012, 01:47 AM   #7
Phishfood, The stems are all the same but they make different trim for the same shower valve. Here is a PDF file that has the stems. (first link) And if you look at Kisslers trim and stem kit you will see the different types of trim they have for the same valve. (second link)
http://www.kissler.com/Downloads/Stems.pdf
http://www.kissler.com/Downloads/Kits.pdf
Old 01-14-2012, 02:02 AM   #8
Success!
The stem is replaced, doesn't leak, and the customer is happy.
