Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > moving and extending shower drain pipe
Old 04-19-2012, 05:45 PM   #1
tcarter
Default moving and extending shower drain pipe
Ok, so I am re doing my bathroom, and Installing a new acrylic shower pan in place of the old shower and the drain of course needs to be repositioned. It have to extend further by an additional 4 inches or so and also needs to move over about the same distance. I have included a diagram to clarify. The existing plumbing is copper, including the P trap with a PVC going vertically to the shower drain. The extension would be simple enough, just cut the pipe behind the P trap, and add a pipe length, but moving it over , or back or whatever, is where I'm not sure.
so questions
1. Is it okay to install an elbow there to redirect it?
2. should i just redo a new P trap with Pvc and tie it into the copper with the rubber sleeve and install an elbow behind the P trap to redirect it or leave the copper P trap and extend with new copper?
3. Is there a flexible pipe/tubing I can use instead?
tcarter is offline
Old 04-19-2012, 09:35 PM   #2
Liked 385 Times on 325 Posts
Likes Given: 551
Is there enough height on the PVC riser to use offset fittings there?
phishfood is online now
Old 04-20-2012, 01:25 AM   #3
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
easyest thing to do would be to chop the copper downstgream of the p trap and extend with pvc and install a new pvc p trap.
make sure you use the correct mj for the job
LiQuId is offline
Old 04-20-2012, 01:31 AM   #4
Likes Given: 219
I would do as liquid suggested. You are much better off to have a direct line from the shower to the trap then to have fittings in between the two.
Old 04-20-2012, 12:39 PM   #5
tcarter
I was planning on having the line be directly from the drain to the trap, where the fittings would come in to place, is downstream of the p trap to reconnect it to the copper pipe. (see new picture, I am sorry it is not to scale) At that point, what should I use? elbows or one of these offset fittings, which I admit i am ignorant of. Also I do not know what the correct mj for the job means. And the vertical "rise" from the ptrap to the floor above is about 7 or 8 inches or so, if that makes any difference.
tcarter is offline
Old 04-20-2012, 12:46 PM   #6
Likes Given: 219
Use the 45 it's much better to have gradual turns in any waste line. Here is a link to the proper coupling to use. They make one to go from copper to PVC as they have different OD's.
http://www.fernco.com/plumbing/shielded-couplings/proflex-couplings
Old 04-20-2012, 02:43 PM   #7
tcarter
Thanks. The 45 it is then.
tcarter is offline
Old 04-24-2012, 04:40 PM   #8
tcarter
Uh, I actually don't know why I didn't think about this before, duh. All I have to do is twist the new P trap in the direction of the new hole. I only need 3-4" no elbow is needed.
tcarter is offline
Old 04-24-2012, 05:01 PM   #9
Likes Given: 219
You of course can do that but I don't like that fernco coupling between the trap and the shower. You would be better off cutting the copper before the trap and using a PVC trap.
Just my opinion.
Old 04-25-2012, 12:48 PM   #10
tcarter
Okay here's a better picture of what I had in mind. Is this cool? The previous illustration showing the coupling between the tail piece and the P trap is what is there now, which I will be replacing.
tcarter is offline
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Moving Drain in Slab & Copper Lines In The Way Higgy General Plumbing Help 4 05-07-2011 05:04 AM
Shower Drain Pipe Help bhinhb General Plumbing Help 0 03-28-2011 08:43 PM
moving shower drain in concrete amkaos General Plumbing Help 17 03-03-2011 06:24 PM
Moving toilet drain. jhate83 Toilets and Sinks 5 01-07-2011 02:39 PM
