Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > MOEN POSI TEMP or TANK - please help
Old 11-30-2013, 03:24 PM   #1
MRD
Default MOEN POSI TEMP or TANK - please help
My name is Mike and this is my first post.
I'm in Vancouver BC.
I have a suite below and it was vacant for 2.5 months. No renter ever mentioned a problem about this.
The new renter claims the hot water runs out quickly. Even at 4am, he says the tub only gets 5 inches full before it starts getting cooler. At 4am, I assume the hot water tank is totally full. I don't take baths, so is this typical behaviour?
When the faucet is first on it is very hot.
I already adjusted the scolding limiter so it is completely hot but that apparently didn't solve it.
Would this have anything to do with the moen valve cartridge?
It was only put in 3 years ago and no other tenant mentioned this problem.
How would the cartridge either be letting some cold mix in or ?
I have also read it could be the dip tube on the hot water heater. The tank is 20 years old but we could usually get at least 2 showers (20 mins) before I notice it is only warm not hot.
I don't have the model number but I have the installation manual and it lists several models.
L82382, L82383, TL2301…
Any help or guidance appreciated.
MRD is offline
Old 11-30-2013, 03:40 PM   #2
Liked 420 Times on 351 Posts
Likes Given: 62
Originally Posted by MRD View Post
The tank is 20 years old ...
Welcome Mike! I'm afraid you've possibly answered your own question. You may buy some time by draining your tank to remove the sediment and replacing the heating elements and dip tubes, but remember, most only last 8-12 years.
havasu is online now
Old 11-30-2013, 03:54 PM   #3
MRD
Damn,
so nothing to do with the moen valve… too bad. Is it worth a shot trying to change the cartridge? If the scold limiter is fully off there's no way cold water would be mixing with the hot right?
Apparently this model has a "Posi-Temp pressure–balancing valve maintains water pressure (straight off of the hd website)" could that be malfunctioning?
Thanks for the help
MRD is offline
Old 11-30-2013, 04:03 PM   #4
Likes Given: 62
Anything is possible. Are you having this problem at other faucets around the house?
Old 11-30-2013, 04:17 PM   #5
MRD
I'll give it a test today to try it out. maybe I can get my hands on a few thermometers to actually get a reading.
I haven't noticed except for by the end of my shower it gets just luke warm if the control is fully on hot ( approximately 20-25 minutes total shower time for the two of us).
MRD is offline
Old 11-30-2013, 04:33 PM   #6
MRD
Opened up the aerators on some of the sinks.
Got a piece of metal in one and a 3/4 in grey plastic sliver in the other.
Could be parts of the dip tube?
Thanks again
MRD is offline
Old 11-30-2013, 04:44 PM   #7
Likes Given: 62
Usually a dip tube will dissolve, but small chunks of the zinc might possibly wash downstream. As far as the plastic, this was probably residual from the plumbing or faucet installation.
Old 12-01-2013, 03:09 AM   #8
Liked 391 Times on 328 Posts
Likes Given: 556
I would expect a dip tube problem to show up rather quickly in the hot water usage cycle , so I don't think that is your problem. At 20 years old, your tank is overdue for replacement, and that would remove a lot of possibilities.
No mid temp at faucet pickngrin Toilets and Sinks 5 02-19-2013 12:48 AM
Show has no temp control flchris Showers and Tubs 5 06-26-2012 04:50 AM
Shower Pressure and Temp. Problems Mantis General Plumbing Help 63 02-16-2011 12:04 AM
Water temp varies, sometimes only luke warm Left-is-Hot Water Heaters and Softeners 11 05-27-2010 12:29 AM
