Hot water surges
I have a tankless water heater and I have 2 showers one is fine, the other starts off normal (hot) then gradually gets colder and colder until it's ice cold. If I play with the handle then it sometimes spurts a higher pressure like air was in the line, and then get warm again and repeat itself.
It seems to be just this shower. The plumber came over and he said he tightened the device inside of it and it should fix it but it didnt work when i took a shower today.
Should I just replace it?
FYI - this shower is the closer then our other shower to the heater. The kitchen which is the closest doesnt do this.
Reason: moved for better visibility
