Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Showers and Tubs > Help removing tub/shower stem cover
Old 02-05-2012, 10:57 PM   #1
Default Help removing tub/shower stem cover
Hello all,
I am trying to repair a dripping tub/shower faucet. I understand such leaks are usually caused by worn valve stem washers, seats, packing, etc. I have managed to remove the hot, cold and diverter handles, but there are smooth chrome sleeves covering the stems that I cannot figure out how to remove. To compound the problem, there is no gap between the grout and the sleeves. So my questions are:
  • Do I need to chip away the grout to remove the sleeves?
  • How do I remove the sleeves?
  • After removing the sleeves, will I then be able to use the stem removal tool that looks like a big spark plug socket? (In other words, will the part of the stem that the tool fits be exposed once the sleeve is removed?)
The trim around the faucet handles said "Standard", so I guess that's the brand. I'm not sure if that refers to American Standard or not. The house was built in 1963, and I assume it is the original tub fixture.
Thanks in advance for any help!
Evangogh is offline
Old 02-06-2012, 02:06 AM   #2
Liked 123 Times on 111 Posts
Likes Given: 70
Remove the grout around the sleeves then just unscrew them. And yes the socket will work.
Old 02-06-2012, 02:20 PM   #3
Thanks for the reply! Is there another tool to remove the sleeves, or can I just use pliers? I chiseled out some of the grout and sprayed them with Liquid Wrench, but they still won't budge.
Thanks again!
Evangogh is offline
Old 02-06-2012, 02:53 PM   #4
Plumbero007's Avatar
Looks like somebody in the past inserted sleeves before tile job was completed. Use small chisel or old screwdriver to chip mortar around sleeves, then try to unscrew them.
This old faucet should be replaced. Just changing stems my not work for long.
You will have to unscrew those stems and seats to replace them.
What is on the other side of this wall? If you have acces to back side of the valve it will work better for you to just replace the whole thing.
Stan
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Old 02-06-2012, 10:58 PM   #5
Likes Given: 70
Thanks again!
Not sure what make faucet you have but you can get a rebuild kit that will replace stems,seats and all the trim including the handles. If I new the make I would be able to point you in the right direction.
Old 02-13-2012, 08:03 PM   #6
Default Fix dripping spout, now have spouting stems!
So, thanks to the previous advice, I was able to remove the stems. I bought stem repair kits for American Standard Colony faucets (I found a stem that matched perfectly) from Home Depot and replaced all the parts. Once I installed them, although the tub spout no longer drips, the hot & cold water stems now spout water from the holes at the end where the handles go! Any tips? I made sure I replaced the washers exactly as they were originally.
Thanks again for the help!
Evangogh is offline
Old 02-13-2012, 09:19 PM   #7
Likes Given: 70
It sounds like the packing nuts a loose. A picture of the stem would help.
Shower Stem Valve Identification Help OrmondAdam Showers and Tubs 1 04-20-2012 09:52 PM
HELP ~ Remove a tub/shower stem justforfunorama Showers and Tubs 1 03-31-2012 02:20 PM
Identifying a Shower Stem bcpux Showers and Tubs 1 02-17-2012 09:03 PM
Can anyone ID this shower valve stem? mmuratet Plumbing Products 2 07-25-2011 12:59 AM
Shower stem issue stryker221982 General Plumbing Help 12 03-17-2011 01:11 AM
