03-05-2010, 07:22 PM
Infrequent User
Floor coating for concrete shower floor
Just installed a bathroom in my shop. The floor for the shower is just a depression with a drain in the concrete. The finishing of the concrete left some rough spots.
What is the best coating to use for the shower area? Epoxy is what comes to mind.
03-05-2010, 10:20 PM
What type of material do you have on the walls? Is the seam watertight? Is it possible you could add a picture, so we could provide you with some ideas?
03-06-2010, 01:44 AM
Infrequent User
Just framed up at the moment - have not decided for sure on walls. Probably green sheetrock.
My question was about what to put on the floor, but any suggestions are appreciated.
03-06-2010, 01:48 AM
Nice! After seeing the picture, I would go with tile, but then again, tiling is my specialty.
03-06-2010, 01:57 PM
Another vote for tile, both for the floor and the walls, at least in the shower area. Not that expensive if you go with bare bones smaller tile.
03-07-2010, 03:37 AM
I would use Hardi backer or Durack cement board instead of Green board since that will hold up al ot better but for the floor yes tile is the way to go.
03-08-2010, 03:22 PM
Infrequent User
Wife has declared that tile grout is too much trouble to keep clean. She wants a "no grout cleaning" solution. The only thing I know of is a painted epoxy floor (how many coats?). The depression is not sized for any standard shower tray.
This is basically a big shower room with a toilet. A utility sink will be placed outside the room on the wall by the door.
03-08-2010, 03:31 PM
If you do go the route of epoxy make sure you add a non slip agent to it so you dont break any legs while showering.
03-10-2010, 05:19 PM
Infrequent User
Absolutely!! Not sure whether I would go ground walnut shells or sand.
03-10-2010, 05:50 PM
Ouch...maybe some roofing nails as an added treat. I guarantee you won't slip!
Seriously, I just epoxied my garage, where I had a bad slipping problem. I added two bags of the silica sand to the epoxy, and double coated the really bad areas. It worked great!
