Originally Posted by GiantSquid
Sorry, I went and edited it since i did find out how to shut off the water. Even if I didn't need to, it was good to know anyways. But yeah...the ball assembly. I can't remove that face plate without getting that off and I'm not sure what tool I need to do it.
Is it a metal handle or plastic handle Delta? if its plastic you will need to remove the index button that tells you hot/cold. Then use a screwdriver to remove the screw. Pull the handle off.
If it has a metal handle you will need the proper allen wrench.
You do not need to remove anything else other than the two screws and then the cover plate. The diverter will be right there...use a socket to remove the diverter.
Goodluck to you!
