Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Cold Shower
Old 12-15-2013, 04:19 PM   #1
jdmann
Default Cold Shower
We have two bathrooms, a guest and the master, and the guest has a bath/shower combo, but the master has a separate bath and shower. The guest has hot water flowing pretty consistently and the master bath has lava coming out the the faucet, but the master shower never has hot water. It's lukewarm at best. Any ideas as to why that is or what could fix it? BTW all the faucets have separate hot and water handles, except the master shower. I'd appreciate any suggestions!
jdmann is offline
Old 12-15-2013, 08:19 PM   #2
Liked 385 Times on 325 Posts
Likes Given: 551
Many newer shower valves have a temperature limit device in the handle. This can be adjusted to limit how far to the hot side the faucet can turn, so that you can't inadvertently scald yourself. If you could post a picture of your valve with just the handle removed, we might be able to help you further.
phishfood is online now
Old 12-17-2013, 02:54 PM   #3
jdmann
Seems like the screw inside the handle is stripped out, so once I magically get that out, I'll throw a picture up here.
jdmann is offline
Old 12-17-2013, 03:02 PM   #4
jdmann
Which any suggestions on how to get that stripped screw out would also be quite welcome. I have a set of ProGrabIt's, but the hole on the handle is too small to fit anything aside from the necessary allen wrench in.
jdmann is offline
Old 12-17-2013, 04:15 PM   #5
Likes Given: 219
What make faucet is it? If your not sure post a picture of it.
johnjh2o is online now
Shower Cold Water jbez General Plumbing Help 6 10-03-2013 10:19 PM
water help, please!!! 1 cold shower to many crankbait09 Water Heaters and Softeners 3 01-10-2013 02:13 AM
Shower - hot to cold Styx555 Showers and Tubs 1 08-22-2012 09:57 PM
shower temp goes hot cold hot cold kawi027 General Plumbing Help 8 04-24-2012 08:10 PM
Gas heated shower going hot and cold? slogger Water Heaters and Softeners 1 01-03-2011 01:47 AM
