Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Bathtub valve id
Old 01-09-2013, 12:27 PM   #1
toasteronwheels
Default Bathtub valve id
Hi I'm brand new to the forum. I have installed my own toilet and sink in the past and hope to be of some help to others. At first I'm looking to see if anyone can identify this valve brand, and maybe let me know how to remove it since its leaking. Thanks in advance.
By the way it's a house I'm moving into so I'm not responsible for how dirty that thing is
toasteronwheels is offline
Old 01-09-2013, 01:42 PM   #2
toasteronwheels
I hope this helps some other. What I found is that this is a mown brand, and you have to pull the metal outer sleeve off to get at the inner cartridge. There is a metal pin you have to remove by pulling it up in order to pull the cartridge out. I will take pictures and post when I remove this. Thanks.
phishfood Likes This
Old 01-09-2013, 09:57 PM   #3
Likes Given: 218
It is a Moen and if you call there 800# they will send you a new cartridge free of charge. You are correct on how to access it. Just be sure the water is off.
Old 01-10-2013, 01:00 PM   #4
toasteronwheels
Thanks although I need it done ASAP so I'm going to just buy the new cartridge. Any idea what do do if the sleeker seems stuck it's the outer metal thing in the above picture I'm not sure what to call it.
Old 01-10-2013, 01:08 PM   #5
Likes Given: 218
You won't have any trouble removing the chrome peace, it just pulls off. You may have a problem removing the cartridge but they do have a puller for that. Also keep in mind that may of the cartridges that are sold in big box stores are after market and there have been some problems with them. If you get it from Moen you can be sure it's OK. You will have it in a week if you call them.
Old 01-10-2013, 02:02 PM   #6
toasteronwheels
Cool. I got the decorative plate off I was referring to the circular metal tube outer shell thing pictured above. Don't I have to slide that off to get at the metal pin to pull It up to make it so I can pull the cartridge out.
Old 01-11-2013, 01:49 AM   #7
toasteronwheels
So I got the sleeve off the valve and it was not too bad. Then I removed the pin and last pulled out the valve. Here are the pieces.
Old 01-11-2013, 02:49 AM   #8
Likes Given: 218
Good job. If after you get the new stem in and the hot and cold are back wards then remove the handle and rotate the stem 180 degrees.
Old 01-11-2013, 03:00 AM   #9
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Originally Posted by johnjh2o
Good job. If after you get the new stem in and the hot and cold a back wards then remove the handle and rotate the stem 180 degrees.
I've learnt that one on my own from experience
Old 01-15-2013, 10:21 PM   #10
mtexplorer
Inspect the inside of the valve before putting the new cartridge back in. If it' scaled or pitted really bad it will damage the o-rings on your new cartridge. I use a product called Santeen. Get mine at ACE but it's available probably at other locations. WEAR safety glasses and gloves when using it and keep it away from the Chrome. It will discolor anything with chrome/nickle. I just use a squirt bottle and use it sparingly with a brass bottle brush. Rinse it well after this treatment. Re-inspect the barrel of the valve, if it's really damaged then consider replacing the valve. Otherwise you might be replacing those cartridges often due to the o-rings and seals being damaged.
I also lube the new cartridge and the valve barrel up well with plumbers grease to help not damage the o-rings and seals.
Good luck
mtexplorer is offline
BathTub Spout jpm6621 General Plumbing Help 7 12-23-2012 03:01 PM
caulking bathtub dolfans Showers and Tubs 2 04-17-2012 07:26 PM
Bathtub Installation joe51 General Plumbing Help 7 03-14-2012 12:20 AM
How do I install a diverter valve in a bathtub? jimmy328 Showers and Tubs 5 01-18-2012 10:44 PM
How to remove valve stem in single handle bathtub faucet. wndrwmn67 Plumbing Tools and Equipment 20 03-12-2011 05:51 AM
