Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Zanne's disposal problems
Old 12-11-2013, 04:15 PM   #1
Zanne
Zanne's Avatar
Liked 67 Times on 63 Posts
Likes Given: 1146
Default Zanne's disposal problems
Yeah. Time to play Taps for that disposal. Anyone know good ones to get? I need a new one too (although I might just go without since I have a septic tank and am not supposed to have one-- but have had one for over 20 years).
Zanne is offline
Old 12-14-2013, 04:59 AM   #2
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Get a badger model.. They are industry standard you can buy at the depot. 1/2 and 1/3 are on but I like 3/ 4 the best
camaroderrick73 is offline
Zanne Likes This
Old 12-15-2013, 01:29 PM   #3
Zanne
Zanne's Avatar
Likes Given: 1146
Thanks! I'll look into them and see which of the models seems to have the best ratings.
Zanne is offline
Old 03-07-2014, 02:40 AM   #4
SHR
Liked 22 Times on 18 Posts
Likes Given: 44
I recommend Insinkerator Badger 5 for low-cost basic or an Insinkerator Evolution series if you want premium performance that will not disappoint you. Check disposal reviews and decide what will best work for you and your wallet.
SHR is offline
Old 03-08-2014, 02:12 AM   #5
Zanne
Zanne's Avatar
Likes Given: 1146
Thank you! I'll have to look for those models. I should measure my old one. I know its a Kenmore 3/4hp one. It still looks all shiny but it is quite old. I think at least 20 years, but I'm not certain. It finally died out. Although I should test the power plug for it to make sure that its not the electrical outlet that died...
Zanne is offline
Old 03-10-2014, 04:18 AM   #6
SHR
Likes Given: 44
20 years is a great lifespan for a disposal! Kenmore disposals are made by the same company as Insinkerator so all of the connections should be the same or similar. Check your existing power connection to the disposal. If it is hardwired re-use the same connection. If it was plugged in via a cord, check the cord for wear. If it is in good shape you can re-use or just replace it with a $12 new cord. Good luck!
SHR is offline
Old 03-10-2014, 11:59 PM   #7
Zanne
Zanne's Avatar
Likes Given: 1146
Thanks. It's the plug in to an outlet type. I'll have to examine the cord and test the outlet later.
Zanne is offline
Old 03-11-2014, 01:45 AM   #8
Liked 419 Times on 350 Posts
Likes Given: 62
Many disposals have a reset button in the base. It is also quick to check current by running an extension cord to see if the disposal works.
havasu is online now
Zanne Likes This
Old 03-11-2014, 08:15 PM   #9
Zanne
Zanne's Avatar
Likes Given: 1146
Ok. I'll have to see if I can locate a reset button on it.
I went and looked-- and it seems like I hallucinated because I thought it plugged in underneath, but when I checked this time its got a wire going up into the wall so its hardwired. My memory is just not working for me these days. I couldn't get into the space to find the reset button, but I did get pictures. I should probably start a new thread because I feel like I've unintentionally hijacked this one.
Zanne is offline
Old 03-12-2014, 12:28 AM   #10
Likes Given: 62
I took care of your thread situation buddy.
Zanne Likes This
Do I have the flange/disposal pmgirly General Plumbing Help 3 02-11-2014 02:42 PM
Kenmore disposal problem Whiznot General Plumbing Help 0 12-16-2013 06:31 PM
What's my next step in fixing the disposal? jakethompson General Plumbing Help 4 02-05-2012 11:23 AM
Need to replace the disposal? Bluesky General Plumbing Help 14 10-18-2011 03:38 AM
Reinstalling Disposal dwh1262 Toilets and Sinks 4 06-08-2011 08:22 AM
