Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Water Hammer after flushing
Old 05-18-2013, 12:02 PM   #1
newbie666
Default Water Hammer after flushing
I have an intermittent problem with water hammer when I flush the toilet. I hear this jackhammer like sound and I can see the flexible supply pipe going to the toilet vibrate. There is no water hammer anywhere else. I live in an apartment style condo. If I take the lid off the tank and hold the float up it stops sometimes. I have been told 2 different answers. One is to replace the fill valve. The other thing is to replace the seal on the tap of the supply line, which is much harder to do because I would have to get the water shut off for the whole building to do this. So which is the most likely culprit?
newbie666 is offline
Old 05-18-2013, 12:09 PM   #2
Likes Given: 219
Replace the fill valve with a fluid master fill valve.
Old 05-18-2013, 10:12 PM   #3
newbie666
I got a fluidmaster toilet repair kit and did the whole works. The small dome shaped gasket on the supply hose was dried out and cracked could this have been the cause. . Now the toilet is topping it self up every once in a while briefly. What should I do to determine where it is leaking.
Old 05-18-2013, 11:59 PM   #4
Liked 416 Times on 347 Posts
Likes Given: 62
If you place a few drops of food coloring into the tank, you will probably see the colored water migrate into the bowl. If you replaced the flapper, did you run you finger under the seal to make sure you have a good seat?
Old 05-20-2013, 03:22 PM   #5
newbie666
I didn't have any food coloring, but did this instead. I shut the supply valve off before going to work and when I got home the tank was almost empty. The water was in line with the flapper, so I assume its the flapper the way its sitting. Tried 3 different flappers and still the same. Noticed the fill valve was intermittently dribbling water on the top opposite to the dial where you adjust your floater height. Tried a different fill valve and the same thing. I have tried many combinations of flappers and fill valves and still the same issue of it filling itself up for a split second every 5-10 minutes. At least I got the slow filling and water hammer fixed.
Old 05-20-2013, 03:59 PM   #6
Likes Given: 62
A picture from inside the tank would be better than a thousand words about now.
Old 05-20-2013, 04:26 PM   #7
newbie666
Here is a pic. I hope this gives a better idea
Old 05-20-2013, 07:14 PM   #8
Likes Given: 62
OK thanks. Is the chain loose enough so the flapper is allowed to seat all the way? I guarantee your problem is within the flapper or seal. Worst case scenario is that you would need to replace the fill tube and seal underneath it, if you can't get a good seal with the existing flapper. Is there a chip out of the seal or possible crud (calcium) where the flapper and seal meet?
Old 05-20-2013, 07:23 PM   #9
Likes Given: 219
How far is that refill tube down into the overflow tube? If it's below the water level in the tank it will siphon the tank causing the fill valve to come back on.
Old 05-20-2013, 08:09 PM   #10
Liked 177 Times on 145 Posts
Likes Given: 124
Looks Like the fill tube is above the flush valve. I think Havasu is correct that it is a flapper problem. I would replace the flapper with this flapper. http://www.homedepot.com/p/KOHLER-2-in-Flapper-without-Float-GP87449/203178248?N=c69o#more_info Rubber your finger around the flush valve seat (where the flapper sets) to make sure it's smooth
Water Hammer Arresters mcintoshmc General Plumbing Help 10 03-22-2013 04:07 AM
Water hammer trouble Komodo General Plumbing Help 7 05-13-2011 12:54 AM
water hammer at washing machine only... k5ranger General Plumbing Help 5 02-22-2011 10:08 AM
Water Hammer opsuv83 General Plumbing Help 4 02-20-2011 10:50 PM
Water Hammer DennisF General Plumbing Help 20 07-30-2010 05:53 PM
