Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Update to Jury-Rig system under sink - New problem: drips
Old 11-30-2013, 11:42 PM   #1
medicine
Likes Given: 2
Default Update to Jury-Rig system under sink - New problem: drips
I've modified the Jury Rig under my sink from this post: http://www.plumbingforums.com/forum/f8/what-4th-inlet-size-pic-5126/
to the following pictures below:
To recap:
Making a sink faucet quick release part for a portable clothing washer machine work from coming off the water inlets under the sink.
I split the cold water inlet with a great inlet extension pressurized piece that I found at a Truvalue hardware instead of home depot.
Then I replaced the original jury rig with the proper thread connections.
Sink faucet connection converted to hose thread piece then converted to pipe thread piece.
I have different on-off thingies as you can see.
Now I have leaks.
I have a leak on the right side of the photo where the galavanized iron piece meets the male-male adaptor piece and again where the wall end of the on-off piece meets the copper pipe extension piece.
Is the correct solution:
1) get a better and bigger pipe wrench and bigger cresecent wrench? (I'm having a problem where my medium size crescent wrench is slipping off the nut on the copper "on-off" piece -- I'm worried about rounding it.
2) re-doing the teflon on the pieces?
3) call a plumber?
4) do nothing, use a bucket under it and hope that the water corodes the drip closed?
Thanks for your help,
I'm not sure if the picture upload shows the drip location, the forum drastically reduced the size of the photos.
medicine is offline
Old 12-07-2013, 11:37 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 550
I have never had much luck at all using just teflon tape to seal metal threads.
I am currently using a high quality tape and Rectorseal #5 pipe dope, and leaks on threaded joints are a very rare occurrence for me these days.
Zanne Likes This
Shower/Tub Trim Kit Update jessb_55 General Plumbing Help 5 10-20-2013 11:13 PM
Jury Duty havasu General Discussion 36 12-02-2011 04:37 PM
Mosquito problem. Has anyone plumbed malathion into their irrigation system? RakeThrower General Plumbing Help 1 09-27-2011 02:32 PM
Update: Line backed up again, now what? arsenik General Plumbing Help 4 07-23-2011 06:35 PM
ballcock drips gymgrrl Toilets and Sinks 8 01-12-2011 05:57 PM
