Hi, long story here but to give background I must ramble-sorry. We had to replace all the insides (don't know technical term) in the back of the toilet because it kept running. When that didn't work we again bought another new kit (thinking we broke it) Now it will flush but not fill back up until you turn the sink/shower on. And even then sometimes it will still run through the overflow pipe. Since everything has been replaced twice I assume it's another issue. Also our second bathroom all of the sudden needed new fixtures and only sometimes fills back up, but on it's own, no sink needed. This has been ongoing for weeks now and just yesterday our hot water heater's pressure relief valve is leaking. About a month ago we replace some sprinkler valves outside, shutting off all the water while doing so, could this have caused the pressure to somehow flip out and cause these problems. Things I've tried to fix ....
-TOILETS:
*3 toilet kits
*turned main water lines off and ran all water to get air out and then back on
*turning pressure down thinking it's too high
-HOT WATER HEATER:
*turned main water pressure down
*opened valve to purge any pressure
Do I need a plumber? Please help
Thank you!
