Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Toilets and Sinks > Toilet mount after installing tile?
Old 01-27-2013, 03:11 PM   #1
Default Toilet mount after installing tile?
So I am installing tile in my bathroom, and need to know after adding the tile and 1/4 backer board if I need to add a spacer to the mount for the toilet. Im mainly looking to be sure it doesn't sit to low. How high should the plastic mount be from the floor the toilet sits on?
Also I wanted to replace the mount since it doesn't appear to be screwed to the floor. I can't seem to get it to come up from the floor. Does this look like one of the compression ones I just need to turn loose? By the way it seems to be in there good the whole pipe moves when you move the mount.
toasteronwheels is offline
Old 01-27-2013, 03:12 PM   #2
This is before the tile. The board and tile will add a half inch.
Old 01-27-2013, 03:36 PM   #3
Liked 103 Times on 93 Posts
Likes Given: 19
That looks like a glued down flange. I would just install the backer and tile, then get the fatty, extended wax ring and call it a day.
Old 01-27-2013, 04:10 PM   #4
Cool how high should it normally set? I was thinking about adding a spacer then using a normal size wax ring. I also want to screw it down since it has some movement.
Old 01-27-2013, 04:11 PM   #5
Plumber
AQualityPlumber's Avatar
Liked 7 Times on 6 Posts
Typically the flange should be screwed to the sub floor. Then tile around the flange. It works best if the flange is flush with the finish floor. When this is the case a normal sized wax ring (medium) with a horn should work perfectly. When you set the toilet, if you do not feel it squish down at least a half an inch, pull the toilet and go with a jumbo ring with horn. Then test it several times before caulking it to the floor to ensure no leaks.
Note: Do not rely on the caulking to hold the toilet to the floor, that is the flange bolts job.
A Quality Plumber Inc.
www.PlumbingWA.com
www.APlumber.mobi
www.plumbingwa.blogspot.com
AQualityPlumber is offline
Old 01-27-2013, 04:15 PM   #6
Plumber
Oh yeah, do not use a foreign spacer to fill the gap if needed. You can get smaller wax rings without the horn to double up, just be careful you don't use to much. You can actually plug up the toilet outlet if to much wax squishes inward and blocks the hole. I have had this happen before and the toilet would plug up all the time.
www.PlumbingWA.com
www.APlumber.mobi
Old 01-27-2013, 10:39 PM   #7
Liked 109 Times on 94 Posts
Likes Given: 240
I like to see a little bit of the flange above the floor. Most toilets will sit down flush with the flange sitting on top of the tile. Flush with the tile, I start to worry that you will not always get a good compression and spreading of the wax.
Old 01-27-2013, 10:52 PM   #8
Liked 62 Times on 54 Posts
Likes Given: 15
I agree. However I have done it with flange extensions and just extra thick wax rings on their own with no issues/call backs. If you can extend it definitely do it for what it's worth.
Old 01-28-2013, 01:33 AM   #9
Thanks I bought a circular spacer that fits on the flange and raises it 1/8 inch above the tile. How big of a wax ring should I use with it sitting that high above the tile floor?
Old 01-28-2013, 01:40 AM   #10
Likes Given: 15
Just a standard one should work perfectly
Tile floor around toilet flange on subfloor Thunderbird_ESQ Toilets and Sinks 2 09-27-2011 10:27 PM
Installing a toilet flange FGH Toilets and Sinks 4 01-09-2011 06:55 PM
Installing a new subfloor around toilet flange? rtlplumbing Toilets and Sinks 2 06-15-2010 11:15 PM
Installing new toilet rioduo Toilets and Sinks 2 06-12-2010 11:37 PM
**Wall mount toilet for residetial** PAGEINC13 Toilets and Sinks 5 02-17-2010 03:01 PM
