Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Toilet flushing problem, tried an auger
Old 01-31-2014, 03:05 AM   #1
discord
Liked 2 Times on 1 Posts
Default Toilet flushing problem, tried an auger
Hi,
I moved into a apartment recently, and about 2 weeks ago the toilet clogged. I asked the manager if he had a plunger. He had a real cheap one, and it wouldn't even cover the drain. I bought a 3' toilet auger, and was able to unclog it. However, I started having it's flush get weaker, and it clogged again.
I just got the auger out again, and unclogged it. I also put some baking soda / vinegar mixture. Assuming that the toilet clogs again, what can I do? Is it possibly in need of a longer auger? I really don't want to have to unclog the toilet every few days. The building is really old, but I notice a brass drain access ( knockout?? ) cover between the shower and the toilet.
Since I have already attempted to fix the issue myself, is it now the landlord's responsibility? What if the issue cannot be resolved?
discord is offline
Old 02-01-2014, 12:06 AM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
I don't know landlord/tenant law in my area, let alone your area. But absent abuse on the part of the tenant, I would think that clogs would be the landlord's responsibility.
If it really is a very old building, it likely has cast iron drain piping, which tends to scale up and clog over time.
Old 02-05-2014, 02:46 AM   #3
discord
The toilet clogged again. I really don't enjoy needing to get the auger out every week or two. Besides it's dirty when that happens. I'm going to make a video of the flushing behavior to get an opinion if it's the flush that's the problem, or the drain. I've never had a toilet clog on me so often. I'm going to talk to the manager tomorrow. I have a suspicion they know there were issues with the toilet before renting to me but never disclosed that.
discord is offline
Old 02-11-2014, 03:52 AM   #4
DIYeverything
Do It Myself And Save
I had a first generation low flow "water saver" toilet that used to clog frequently simply because of poor design and too-low of a flow. Replacing the toilet solved it.
DIYeverything is offline
Old 02-11-2014, 09:39 PM   #5
discord
I finally had a chance to post this video of the clogging toilet. http://youtu.be/A03nz2YVq7U
discord is offline
Old 02-11-2014, 10:33 PM   #6
discord
How old are the first gen? this toilet looks pretty new.
discord is offline
Old 03-16-2014, 07:51 AM   #7
gioplumbing13
Might be a venting problem
Sent from my iPhone using Plumbing Forum
gioplumbing13 is offline
Old 03-16-2014, 02:46 PM   #8
plumbdrum
Banned
Liked 17 Times on 16 Posts
The flushing rim may be blocked due to past tenants using tank cleaning blue or green gel, it dissolves and gets stuck in the rim. By the look of the flush and the inside parts of your tank you should have more of a spiral flush.
plumbdrum is offline
phishfood Likes This
Old 03-16-2014, 03:00 PM   #9
discord
I forgot to update the thread. I called a plumber out and it turns out a toothbrush was stuck in the trap. He was able to see it with a flexible camera, and use an auger to remove it.
discord is offline
2
People Like This
Toilet flushing problem Purley Toilets and Sinks 3 01-16-2014 12:23 AM
Toilet flushing problem chele519 Toilets and Sinks 5 03-05-2013 03:06 PM
Toilet auger won't go in far fwegan Plumbing Tools and Equipment 10 01-24-2012 02:22 AM
Toilet Flushing psk09 General Plumbing Help 1 10-12-2011 09:18 PM
Toilet Auger: From Bad to worse Diem Plumbing Tools and Equipment 4 04-30-2011 12:18 AM
