Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > toilet flange not level with floor. please advise!
Old 07-10-2012, 03:29 AM   #1
daemoniscinxi
Default toilet flange not level with floor. please advise!
Hello,
My wife and I just bought our first house and we were told by the inspector that there was a leak under the toilet (the previous owners had just replaced the wax seals). So we took the toilet off and found that there was only a closet flange screwed into the plywood with no seal between the 3" pipe and the ring:
http://www.flickr.com/photos/69424450@N07/7540303394/
The metal closet flange was bent, which could have been why it was leaking or because there is a gap between the ring and the pipe as you can see in the picture. Rather than just replacing the metal ring with another, I thought I would try to make something that would be a bit more safe, so I bought a 3" inside fit flange. I had to use a dremel to clean out a bit of old product that had dripped down the pipe that was preventing me from inserting the flange, but after smoothing it I was able to insert the flange. However, as you can see from the pictures below, the pipe coming from the floor is not perpendicular to the floor and also is raised off the floor slightly, causing the flange to not lay flush on the floor:
http://www.flickr.com/photos/69424450@N07/7540301390/
http://www.flickr.com/photos/69424450@N07/7540299272
http://www.flickr.com/photos/69424450@N07/7540296628
http://www.flickr.com/photos/69424450@N07/7540293138/
Does this slight slant matter, or will the wax seal take care of this? Should I use a reinforced wax seal or a standard one? Should I cut off 1/2 inch from the pipe so that the flange lays somewhat level with the floor (even if at a slight angle)?
Thank you for your time!
daemoniscinxi is offline
Old 07-10-2012, 11:37 AM   #2
Likes Given: 218
The slight angle will be OK but the flange needs to be lowered. Cut the pipe to lower the flange so it sets on top of the floor. Just be sure to screw it down. A standard wax seal will be fine.
Old 07-10-2012, 11:48 AM   #3
Liked 177 Times on 145 Posts
Likes Given: 123
Correct me if I am wrong, But it looks like a standard plastic flange being put in a cast iron 90.
Old 07-10-2012, 12:27 PM   #4
Likes Given: 218
I sure hope not. Maybe he will post us a answer to that question.
Old 07-10-2012, 04:36 PM   #5
daemoniscinxi
The pipe is a 3" PVC pipe that runs parallel under the floor before angling up to almost perpendicular to the floor. There was old silicon product that was around the mouth of the pipe that was preventing me from putting an outside fit flange on. I used a dremel to remove the approx 5mm of product that was around the circumference of the opening of the pipe.
Old 07-11-2012, 08:15 AM   #6
Likes Given: 123
PVC pipe is white, ABS pipe is black. That really looks like a the hub of a 90 sticking out the floor. Again, I could be totally wrong.
Old 07-11-2012, 07:32 PM   #7
daemoniscinxi
It is a black pipe. Sorry, I did not know the difference between PVC and ABS plastic pipes. So it could be ABS; I'm not sure.
Old 07-11-2012, 08:26 PM   #8
Likes Given: 218
Just screw it down and use a single wax seal when setting the toilet.
Toilet Flange Flush or Above Finished Floor? Bogucki General Plumbing Help 6 07-03-2012 01:27 AM
toilet flange not level causing leak smel General Plumbing Help 3 03-17-2012 01:54 AM
Flange Not Flush Wth Floor vabear Toilets and Sinks 2 02-06-2012 07:34 PM
Tile floor around toilet flange on subfloor Thunderbird_ESQ Toilets and Sinks 2 09-27-2011 10:27 PM
Toilet Bowl Water Level Alternates Level and Flush leichte Toilets and Sinks 2 09-15-2010 02:00 PM
