There is no way to control the water level in the bowl, unless there is not enough water in the tank when flushing. There should be a small tube going from the fill valve and into the overflow pipe. This assists in getting the proper refill. Otherwise, the level is controlled by the trap in the bowl.It can only fill a certain amount, and then the trap overflows and the water goes into the drain pipe.
