Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Toilets and Sinks > Toilet bowl drains slowly.
Old 04-10-2012, 11:23 PM   #1
Default Toilet bowl drains slowly.
i have a toilet that i just installed that slowly drains the bowl after the flush is complete.
It flushes perfectly, tank and bowl fill up at the same point, everything is good until the fill valve shuts off and then the bowl water slowly drains. i checked the gaskets on the flush valve, replaced the flapper, and checked the clean out with no visual obstruction ( however its kind of hard to see all the way back to where the Toilet tees in).
but heres the kicker, when i turn the tub on full blast (which is up-hill from the toilet on the main drain) the toilet will hold its level in the bowl.
Thanks any help would be great.
andyismarine is offline
Old 04-11-2012, 09:03 PM   #2
philly_plumber's Avatar
It sounds like you may have an obstruction in your main line. This explains why toilets drain slowly even though there is no clog. Whether is it mineral deposits, tree roots or some other type of foreign object, I recommend getting the issue resolved before you have a big mess to deal with.
philly_plumber is offline
Old 04-29-2012, 12:59 AM   #3
Try.running a toilet auger through the bowl...no luck then inspect main sewer but if there's a stoppage in main line it will show up at lowest point ie. Shower or tub
Joeypipes23 is offline
sink drains very slowly kootenaybk General Plumbing Help 12 07-09-2012 12:54 AM
Toilet valve sucking water out of bowl. Refilling bowl every few min. Nichols Toilets and Sinks 2 06-16-2012 09:34 PM
Shower drains very slowly PlumbingNoob Drain and Sewer Cleaning 10 06-06-2012 01:12 AM
new bathroom drains slowly theron621 General Plumbing Help 3 02-08-2012 11:28 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
