I think the problem is the toilet, not the drain line. Make sure the water level in the tank is about 1/2" below the overflow tube. flush and see if the flapper stays up until most of the water is out of the tank. With a mirror, check the holes under the bowl rim to see if they are running free or clogged. If the water in the bowl does not rise when flushed, this tells me the drain is running fine, but the toilet is not producing enough water to give a full flush.
