Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Quick "I dropped something in the toilet" Thread
Old 11-03-2010, 12:02 AM   #1
joneytheman
Default Quick "I dropped something in the toilet" Thread
I dropped a bowl for a "tobacco smoking water pipe" in the toilet. It is only about an inch long and it looks like this:
Somehow I managed to flush the toilet after it fell in and I can no longer see it. I have a toilet auger, but I don't think using it is the best solution.
The toilet still flushes and is showing no symptoms of being clogged. Should I attempt to remove it? If YES, any suggestions on the best way of going about removing it?
Or, is doing nothing and leaving it in the toilet a 'safe' option? It is made of glass, so I am slightly worried. But since the toilet is showing no signs of any problems, I am tempted to do nothing...Please advise!
Thank you in advance!
joneytheman is offline
Old 11-03-2010, 02:17 AM   #2
Liked 416 Times on 347 Posts
Likes Given: 61
If you have already flushed the toilet more than once, I'm going to assume your "tobacco smoking" (25 years of law enforcement says that is not used for tobacco!) pipe is gone forever. If you have a stoppage in the next few days, then that will be a sign that it is probably lodged within your toilet. If this is the case, pull your toilet from the flange, take outside, and fish out your umm, tobacco smoking pipe.
Old 11-03-2010, 05:24 AM   #3
Chris
Administrator
Liked 494 Times on 436 Posts
Likes Given: 42
I second that your "Tabacco smoking" bowl is gone forever along with your 5 bucks worth of "Tabacco"
Chris is offline
Old 11-03-2010, 06:29 AM   #4
joneytheman
Havasu: Thank you for the response! I used that term so the picture would not be taken down...My goal is not to retrieve the bowl, but to make sure my toilet is not damaged.
If there is no stoppage within, let's say the next week, can I assume that it will not cause a problem?
Or, do you think I better be more safe than sorry and attempt to fish it out before it causes a problem?
Thanks again for the response!
Old 11-03-2010, 12:15 PM   #5
majakdragon
With the small size, and probable light weight, I would say the pipe has traveled to the sewer. As stated, just watch for a slowing of the drainage and then take action.
majakdragon is offline
Old 11-03-2010, 02:23 PM   #6
Likes Given: 61
As Majak has just written, you should be fine. Oh BTW, sorry about Prop 19!
Old 11-04-2010, 04:21 PM   #7
Benny
If it was still there you'd have to pull the toilet to remove it. but something that size is more than likely GONE
Benny is offline
Old 11-05-2010, 09:57 PM   #8
Austin
Administrator
Austin's Avatar
Liked 80 Times on 75 Posts
Likes Given: 223
Could he brake it by running a snake in there and then just flush it through if necessary?
Austin is offline
Old 11-05-2010, 10:16 PM   #9
Likes Given: 61
The OP stated the pipe was only 1" long and if the toilet was worth a crap (no pun intended, but funny!), it is long gone by now.
"The official uniquely randomized designed thread" Chris General Discussion 1274 03-29-2014 01:26 PM
Toilet flushes just fine but still "sings" aoikirin Toilets and Sinks 1 03-23-2012 09:19 PM
Installing toilet in basement of "new" house pooky85 Toilets and Sinks 7 07-01-2011 05:42 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
