Old 03-26-2010, 10:19 AM   #1
Default My toilet is behaving in a strange manner
Hi experts
I'm a newbie on this forum and request help/advice from the xperts to tame my toilet's strange behaviour.
I'm living on the 1st floor in a 16 storied apartment block.There are 4 flats per floor.This strange behaviour of my toilet started around 3 months back and happens intermitently thru out the day and night.The water which is at the base of the toilet seat begins to rise all by itself and makes a lots of noise.If someone is siting on the toilet seat his bum gets wet with dirty water flowing out of the seat with force and creating a bubbling sort of an effect. It continues for a minute or so and then settles down.The seat becomes very dirty and smells a lot.If by chance the seat is kept open and no one is using the toilet and this bubbling starts the water spills out of the seat and makes the toilet floor dirty.Just before this happens I can sense the water gushing down the common drain pipe from the higher floors.
No idea why this is happening.. Can anyone help me out in diagonising this problem.
Thanks in advance.
ash147 is offline   Reply With Quote
Old 03-26-2010, 02:18 PM   #2
There is a partial blockage in the main drain piping. When others in the building use any fixtures, the water is not being drained completely through the piping and is backing up through your line. Call your apartment maintenance or manager.
Old 04-24-2010, 02:40 PM   #3
Originally Posted by ash147 View Post
Hi experts
Thanks in advance.
I would call out a Ghost Buster
Just kidding seems like a blockage along the line somewhere get hold of a plumber
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
Old 05-13-2010, 12:36 PM   #4
Thanks for the suggestion.what u mentioned was absolutly correct and the problem got recitified.
thanks again
Old 05-13-2010, 12:37 PM   #5
yup...i did get hold of a plumber and got the damn thing rectified.
thanks
Old 05-13-2010, 02:49 PM   #6
Unless you are an owner of this complex, I would recommend never calling a plumber until the management has had a chance to correct the problem. By doing so, there is a chance you will not get reimbursed for the cost of the plumber. I understand your problem has been corrected already, so this information is for future tenants who may have similar problems.
bubbling, toilet, toilet seat, water
