Mansfields are notoriously poor flushing toilets.
There is a reason a complete w/ seat Mansfield is under $80 @ Home Depot. They struggle with flushing urine! Unglazed trap way, poor siphon jet design and the flush valve inside the tank only lets about 1 gallon of water through.
Every time a toilet is removed a new wax ring is required to ensure a proper seal has been achieved between the flange and the bowl. Even if you just set it 10 mins ago and have to pull it for some reason.
A leak under the bowl is awful. First waste fills the small cavity between the bowl and the floor. If you did a good job you sealed it in with caulk of some sort. Once the cavity is full, if given a chance the waste will seep in below the tile and water will take the path of least resistance. I have seen it leech its way up the door casing 5 feet from the toilet.
Sorry. Bit of a rant there.
Mansfield sucks. Buy a Toto.
