Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Leaking tank on toilet
Old 02-06-2014, 04:22 PM   #1
garmp
garmp's Avatar
Default Leaking tank on toilet
Please help me figure this out. I know just enough to be dangerous. The story:
My toilet tank was leaking very slowly into the bowl. About a half inch of water out of the tank and then it would refill. Amazingly loud a night. Bought replacement parts, including the $28 Kohler tank to bowl gasket and same thing. Replaced the toilet with an American Standard and was good to go for a couple of months, then the same thing. Called American Standard and they sent out a new flapper. Replaced it and the same thing They then send the whole flapper assembly, including the tank to bowl gasket. Same thing. Called American Standard for actually the third time and they said they would send out another flapper, but turn off the supply and let the tank leak for a day to see how far down it goes before stopping. Did that. It was about an inch and a half below the over flow pipe. Put blue food coloring in to check for leakage. None! It had stopped. Great!!!
Out of curiosity I poured in water up to the normal level and waited to see if die/coloring had leaked into the bowl. And waited. Nothing. I reset the intake level on the float to the original level. All is fine.
So why is it working now at the original levels?
Guess that's why I'm not a plumber.
Thank you for any thoughts.
garmp is offline
Old 02-07-2014, 01:03 PM   #2
oh_io
oh_io's Avatar
Liked 5 Times on 5 Posts
Likes Given: 3
I'm thinking that if you replaced the faulty flapper that was letting water leak into the bowl, now the tank can fill to the original level. No leak, no reason it can't fill to proper level and stay there.
oh_io is offline
Old 02-07-2014, 02:01 PM   #3
garmp
garmp's Avatar
But after turning the supply off and replacing nothing, the leak stopped. Put the food coloring in and seeing no seepage and sitting a day, returned the float to the original position and PRESTO! No leaks. How? Why?
garmp is offline
Old 02-07-2014, 02:16 PM   #4
Liked 420 Times on 351 Posts
Likes Given: 62
Could you get us a inside picture of your toilet tank?
Old 02-10-2014, 05:33 AM   #5
gregg123
That would be better
gregg123 is offline
Leaking Hot Water Tank jsider Water Heaters and Softeners 1 10-19-2013 09:00 PM
Septic tank leaking water onto basement floor, help!? asweiss General Plumbing Help 3 12-24-2011 03:53 AM
Pressure tank faucet leaking. museic General Plumbing Help 6 12-13-2010 01:29 PM
Toilet Tank Leak - Cracked Tank? RobZ General Plumbing Help 5 11-09-2010 10:50 PM
toilet leaking? michaelooch Toilets and Sinks 1 10-14-2010 12:28 AM
