Personally I put the ring on the flange, at the same point in the process that I install the closet bolts. Mr. David had a thread going awhile back that reinforced my main reason why. If the wax ring is on the flange, it can't fall off of the bowl and therefore it is still in place to seal against the bowl. Either way, an attentive plumber feels the resistance as the wax ring makes contact and seals the bowl to the flange. With the ring on the flange, once the bowl starts on the closet bolts, you know that the ring is in the right place doing it's job, rather than lying halfway across the flange, as it might be if it is placed on the bowl.
