Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > How fix a loose Toilet tank handle
Old 01-10-2011, 01:27 AM   #1
Mr_David
Liked 9 Times on 8 Posts
Default How fix a loose Toilet tank handle
Well I had to replace my toilet tank handle so I thought I'd share a little tip that can be helpful.
Often the hole in the tank is larger than the square sides of the handle that are supposed to keep the handle in place.
So I made a video.
Mr_David is offline
Old 01-10-2011, 01:34 AM   #2
Liked 384 Times on 324 Posts
Likes Given: 549
For those of us who are "internet challenged" (read dial-up) can you detail the process in text?
phishfood is online now
Old 01-10-2011, 01:44 AM   #3
Mr_David
I'm literary challenged and the video is my best shot at sharing this tip.
Mr_David is offline
Old 01-10-2011, 01:47 AM   #4
Liked 416 Times on 347 Posts
Likes Given: 61
Nice video Dave!
Phish, Dave's video shows how many times, the square in the porcelain tank is manufacturered a bit too large, so when you insert the toilet tank handle, it will rattle about an eighth of an inch in all directions. He uses plastic copper pipe hold downs/supports, which are about the same thickness as the eighth inch gap in the porcelain. By cutting the wings off the supports, he inserts them into the gap between the handle and the porcelain. Once the handle is tightened, there is no more rattling from the loose fitting handle.
Old 01-10-2011, 01:57 AM   #5
Likes Given: 549
Ahhh, the old oversized flush handle hole!
I always keep several CTS flat straps and suspension clamps in a bucket in my truck. Next time I run into problems with a loose flush handle, I will give this a try.
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Loose Drain Pipe Below Kitchen Sink :( DukeStratosphere General Plumbing Help 5 02-17-2011 06:10 AM
Tub spigot and handle loose Wildduk Showers and Tubs 2 01-20-2011 11:21 PM
Toilet Tank Leak - Cracked Tank? RobZ General Plumbing Help 5 11-09-2010 10:50 PM
Toilet tank will not fill. cnl390 Toilets and Sinks 2 08-01-2010 03:12 PM
