Fixes for flange being set too high?
Hey everyone, new guy here.
We closed on our house on 9/12, and after moving in noticed that the downstairs toilet in the half-bath was loose and rocking front-to-back, with about a half-inch of space between the base and floor at either end. When flushed, a small bead of water would leak out around the base, but nothing major, and there was no wood damage to the wood floors. A plumber was called through our home warranty company (American Home Shield), and when he took the toilet off, he said that the flange was set too high, probably buy the original plumber during construction(2005). He said the only way to fix the problem was to pull up the wood flooring in the bathroom, jackhammer out the concrete slab around the flange/pipe, reset the pipe lower, fix the concrete, and relay the floor. Within 10 minutes of him knocking on my door I had an estimate of $2300 worth of work.
Shocked. He called AHS, and, of course, it wouldn't be covered because it's considered "improper installation or repair". I asked him if there was any simpler way to fix the spacing problem and he said categorically NO, his license wouldn't allow him to do anything other than exactly what he described. He was more than happy to tell me about their financing options, and within 30 minutes of leaving, his girl back at the office was calling to see if I wanted to go ahead with the credit check for the repair financing.
After taking a breather, I started googling, thinking there had to be some kind of spacer or riser that could be a much easier fix to this problem. It seems like there are products out there - I am just wondering if any of you had experience with them or had tips/suggestions?
Thanks so much, sorry for the long-winded synopsis!
