Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Faulty toilet fill valve - or faulty installation
Old 02-26-2012, 05:10 AM   #1
tplo
Default Faulty toilet fill valve - or faulty installation
I installed a Fluidmaster universal toilet fill valve today -- or tried to -- but I may have done it wrong. The valve appears to be leaking water into the tank, keeping the tank filled to the overflow level. (It's not triggering flow from the main water fill tube, so I don't think it's the flapper, which is relatively new). There are also air bubbles in the tank, which is something new.
A few things didn't turn out like the instructions indicated - the coupling nut didn't come off the water supply line (despite some tugging), so I left it in there but put in a new cone washer. And the instructions called for removing the valve top and running the water a few times, then reinstalling the valve top, but I couldn't get that to work. (I think this might have caused the problem). I have tried to adjust the float as well, but that doesn't seem to make a difference. (And a new problem is that I tried to turn off the water below the toilet - it worked during the original installation, but now the water keeps running, or this valve is messing it up).
Any suggestions? Should I buy a new kit and try again or can I fix this one? Thanks!
tplo is offline
Old 02-26-2012, 12:49 PM   #2
It's very rare that you get a faulty Fluidmaster. You may have messed it up when you tried to remove the cap. It also sounds like you have a bad valve on the supply line. This can also be the reason the fill valve isn't turning off. When you turned it off it may have loosened some scale in the valve that is now in the fill valve causing it not to turn off completely. Try following the instructions and remove the cap. There is a disk under the cap. Check for debris between the disk and it's seat. Be sure to turn off the main water supply before taking the fill valve apart. This would also be a good time to replace the valve on the toilet supply.
Old 02-26-2012, 02:13 PM   #3
tplo
Many thanks, John. One quick follow-up: does removing the cap mean just taking off the black plastic cover that snaps on top of the fill valve? I had managed to unsnap that and take it off. But I didn't see the water flowing up from the valve as the instructions suggested would happen during the test process (turning on and off the supply water), so I assumed I was supposed to take off more than just that top cap. Does more of the top assembly above the float come off as well? Thanks.
tplo is offline
Old 02-26-2012, 02:30 PM   #4
Once you remove the cap you have to lift up on the plastic arm the stainless steel wire attaches to.Then rotate the plastic arm 1/4" turn while holding the fill valve below the arm. This will allow you the remove the assemble exposing the disk and it's seat. Check for debris in this area. Let me say again be sure the water is off. I found this link that may be of some help.
http://www.fluidmaster.com/downloadable/download/sample/sample_id/176/
HELP: Faulty Flapper Fiasco nim6us Toilets and Sinks 12 02-14-2013 01:38 AM
Fill valve too high in toilet tank brees6221 Toilets and Sinks 1 03-04-2012 01:20 AM
Toilet fill valve not shutting studiocitylen Toilets and Sinks 3 11-09-2011 11:35 PM
Help with faulty thermostatic cartridge optimas Showers and Tubs 7 06-23-2011 02:30 PM
Crazy bad toilet fill valve Handyguys Project Display 5 04-06-2010 02:45 PM
