If it has a set screw then it is most likely just bonded to the broach on the end of the stem. Those can be hard to remove sometimes . Can't really spray any type of liquid wrench on it, it may damage the finish and counter top.
disconnect the water supply and finish removing it from the sink. Then try tapping on the bottom of the lever with a block of wood.
