Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Toilets and Sinks > Bathroom Sink Base Constantly Leaks
Old 06-27-2012, 05:41 PM   #1
mrcannon
Default Bathroom Sink Base Constantly Leaks
Our Bathroom sink base has been leaking for about 2 years now and I think it's finally driven me insane. It's always flooded by the end of the day and turns a brownish color. The horrible Super in my building has attempted to "fix" it 3 time and it's exactly the same.
I've done a lot of research and mostly just found advice for a leaky faucet, but never information about the base of it leaking. Please let me know what I need to do. I don't know the first thing about Plumbing.
Here is a picture of the leak below.
It leaks from all sides of the base and floods the sink area
Please help.
Thanks!
mrcannon is offline
Old 06-27-2012, 09:43 PM   #2
greenyterrot
Hi! Is it your tap?? If so it could easy be your seal which has just failed or all you will have to do is get some new taps there are not much at all. I just fitted some new taps today and working prefect haha so yeah! It will not take long... If you need any help fitting your new taps or help with getting to the seal just inbox me and I will tell you how to do it set by set! Okay let me know how it all go's thankyou!.
greenyterrot is offline
Old 06-27-2012, 09:54 PM   #3
greenyterrot
Or just looking at your pic again you might just have to put some silicon around the sides of it! Once again let me know how you get on!.
Old 06-27-2012, 10:51 PM   #4
Liked 162 Times on 137 Posts
Likes Given: 87
My guess is the O rings on the stems are leaking. To confirm this remove the handles and turn the water on and see if there is water leaking around the stems.
captaincool Likes This
Old 08-12-2012, 02:56 AM   #5
Jasper
Save yourself the headaches...spend 30 bucks and replace the faucet. It may have an internal leak that no washers or o rings will fix.
Jasper is offline
Old 08-12-2012, 03:01 AM   #6
Liked 134 Times on 114 Posts
Likes Given: 279
I wouldn't recommend installing a $30 faucet.
Old 08-12-2012, 03:26 AM   #7
stevemachine
Liked 65 Times on 57 Posts
Likes Given: 51
Agreed. Spend more than 30 bucks. Even if you do rent the place.
Frangeo Likes This
Old 08-12-2012, 03:51 AM   #8
Likes Given: 87
That faucet looks like an older Delta 2522 faucet. They are very easy and inexpensive to repair.
http://www.plumbersurplus.com/Prod/Delta-2522-Classic-Two-Handle-Centerset-Lavatory-Faucet-Chrome/23393/Cat/1083
http://www.deltafaucet.com/repairparts/details/rp1740.html
The first link it to the faucet. The 2nd link is to the stem needed.
If you call Deltas 800# they will send you all the parts need to rebuild the faucet free of charge.
Old 08-17-2012, 07:09 AM   #9
HortonHyde
HortonHyde's Avatar
I think replacing the faucet is better, for affordable faucets check out this ***no spamming allowed***..
HortonHyde is offline
Old 08-19-2012, 02:02 AM   #10
Jayare
Greenyterrot, I dont think its a good idea to silicone the base. It might look like its fixed but the waters still going to siy under the faucet and rot the counter top
Jayare is offline
Help please with bathroom sink bjack Toilets and Sinks 2 04-28-2012 05:08 PM
Kitchen sink sprayer leaks (or: what is this part?) matbluvenger Toilets and Sinks 4 03-31-2012 02:24 PM
Water constantly running in toilet ihavezippers General Plumbing Help 4 05-19-2011 05:25 AM
Bathroom sink help-newbie homeboyslim General Plumbing Help 1 05-10-2011 01:56 AM
