Go Back   Plumbing Forum > General Plumbing Discussion > Plumbing Products
Old 01-08-2010, 03:19 AM   #1
Default water valve vs gas valve
Is there any difference between the two? Put in a valve for my sprinklers I had it installed before I noticed I had grabbed one rated for gas. Worked for a couple months so far
ozntz is offline   Reply With Quote
Old 01-08-2010, 02:23 PM   #2
While there are specialty valves, most have a rating stamped on them. You will see WOG on the side. This stands for Water, Oil or Gas. Most gas valves are brass and much heavier than standard valves, The other difference is most gas valves open or shut off with 1/4 turn. Ball valves also work the same way. Using a gas valve for water is more preferable than using a water valve for gas. Gas valves seal better.
Old 01-08-2010, 02:40 PM   #3
Thanks guess I will not worry about it
sprinkler valves, water valves, gas valves
