Stop drain backup in stacked drain line
I am the pres of an HOA board of a four story condo complex. We are looking for a device that will prevent flooding of the first floor units when there is a blockage in the drain line below the first floor. All the vertical drain lines are stacked so that the first, second, and third floors all use a common vertical main drain line. There are three condos using each common drain line. If there is a blockage in the vertical main drain blow the first floor there is an overflow in the first floor unit. Many for there units are vacation homes and unoccupied a good part of the time so overflows can go undetected for a long time. Is there a devise that will prevent the back flow and possibly alarm if there is a back flow?
