Plumbing Forum - Professional & DIY Plumbing Forum
General Plumbing Discussion
Plumbing Products
product to fix a leak
User Name
Remember Me?
Password
Register
Plumbing Albums
FAQ
Members List
Search
Today's Posts
Mark Forums Read
LinkBack
06-21-2011, 07:07 PM
1
buckylene
What is a good product to fix a pin size hole in a pressurized pvc pipe in a motorhome?
06-21-2011, 08:12 PM
2
Is it PVC or CPVC? Depending on what it is used for, I would cut out the pin hole and re-glue an appropriate connector onto it.
06-22-2011, 01:02 AM
3
Yup, agree with havasu. I don't use and will not use any 'wonder products' or epoxy repair plugs.
06-22-2011, 06:18 AM
4
majakdragon
Product is called a coupling. Cut the pipe at the pinhole and install the coupling. You are asking for a future leak if you use the "wonder" products.
06-23-2011, 04:51 PM
5
buckylene
Thank you for all the help!
You were right not to try a "wonder" product. I tried rescue 911. It worked for about 10min then the leak was back. So I took the entire pipe off and replaced it today, NO MORE LEAK!!! Thanks again Arlene
06-23-2011, 05:35 PM
6
I'm glad you got the problem fixed and appreciate letting us know the outcome!
Pex in cold weather.
Dual Flush toilets
Show Printable Version
Email this Page
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
Off
Pingbacks
are
On
Refbacks
are
On
Forum Rules
30 x 60 deep 2 apron tub?
Kohler Pompton series leaking water into the bowl
Pex Tubing Runs
American Standard fresh air intake?
Toilet Vent and Wall Size
Custom Shower Design?
1 trillion post thread.....
New here but not new to forum experiences
Recirc question
Nuvoh20?
Content Relevant URLs by
vBSEO
3.6.0
Network:
Flooring Forum
Home DIY Forum
Garage Forum
Painting Forum
Contact Plumbing Forum
Privacy Statement
Terms of Service
Top
LinkBack
LinkBack URL
About LinkBacks
