Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > "Dressing up" a washing machine discharge hose
Old 08-23-2012, 04:54 PM   #1
Solid
Liked 3 Times on 3 Posts
Default "Dressing up" a washing machine discharge hose
The hose hanging of fthe edge of my brand new Mustee utility sink is just ugly. I've seen a couple options out there for this problem, like this:
(reviews say that this doesn't work well at all)
And, Mustee sells this attachment, which I'm thinking about:
(I'm not sure how to attach a lint-catching device though)
Does anyone have any clever ideas, or experience? Obviously, this isn't a big issue, just a cosmetic thing.
Thanks!
Solid is offline
Old 09-05-2012, 12:52 AM   #2
Matt30
Liked 21 Times on 17 Posts
Have a proper washer drain installed and you wont see it at all
Matt30 is offline
Old 10-02-2012, 11:52 PM   #3
Solid
You're right, I should probably just do that. I will say that I am shocked with:
- The amount of water that dumps out of the washing machine
- The force of the water coming out of the discharge pipe
- The amount of lint coming out of the discharge
It might not be a bad thing to strain that water out before it goes down the drain!
Solid is offline
"Male flare 1/4 to Female compression 3/8" Adapter Sly General Plumbing Help 25 07-20-2011 05:13 AM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
Outside spigot with plastic "winterizing" piece causing leak thunderbry General Plumbing Help 2 06-19-2010 01:09 PM
Vice President Joe Biden or Jeff Dunhams "Walter" SilverBack4Jack General Discussion 5 01-30-2010 12:53 AM
Can someone recomend to me a good "homeowner plumbing snake" rustywrangler Plumbing Tools and Equipment 6 01-07-2010 02:15 PM
