Go Back   Plumbing Forum > General Plumbing Discussion > Plumbing Products
Old 05-17-2010, 09:29 PM   #1
Default Bathroom faucet stem
Can anyone identify the maker of this faucet stem? it is about 15 years old and leaks around the base. It is not the seat that is leaking/
Stephen47 is offline   Reply With Quote
Old 05-19-2010, 02:23 AM   #2
I can't ID the stem but if you take it to Lowes or Home Depot, I'm sure you will be able to match it up without too many problems.
Old 05-21-2010, 01:39 AM   #3
I've tried that with no success. The double O ring is the problem. Nobody has seen that.
Old 05-21-2010, 01:46 AM   #4
Can you match it up in all other aspects other than the double Oring? If so, I would be tempted to try one with a single Oring if it looks like it might work.
Old 05-21-2010, 02:10 AM   #5
As I've said in the past, once the parts are no longer available quickly, I believe it's time to bite the bullet and replace your fixture. You will be happier in the long run, and have years of worry free usage.
Old 05-22-2010, 07:50 PM   #6
I tried a single O ring Delta stem. It stopped the leak around the base of the handle but wouldn't shut the water off all the way. I bought new faucets today. Thanks for the suggestions.
Old 07-09-2010, 01:20 PM   #7
Hi Stephen47
I just can' identify the brand of this faucet stem. You can get help from plumbers you know. If this faucet stem is really 15 years old then it is better to replace this one with a new.
Thanks
Denzel Parker
Bancroft Bathroom Faucet
DenzelParker is offline   Reply With Quote
Old 12-09-2010, 03:46 AM   #8
Try valley or delta also change the rubber cups and spings if u canm
hplumber08 is offline   Reply With Quote
Old 12-09-2010, 03:58 AM   #9
Plumbing Sales
SlowDrip's Avatar
The thread is seven months old, i hope to god he isn't still looking for this stem.
stem, faucet stem
