Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Vent pipe question...
Old 03-31-2013, 05:36 AM   #1
1234
Default Vent pipe question...
Dear Sir/ Madam,
How can I fined the actual size of the vent pipe to roof,
For Example if we have
WC = 6
Lavatory = 10
Shower = 8
Thanks I wait for your information.
1234 is offline
Old 03-31-2013, 01:32 PM   #2
Liked 189 Times on 137 Posts
Likes Given: 112
If all fixture vents connect before exiting the roof, the vent seen from the roof top will be 4".
Old 06-05-2013, 07:15 PM   #3
EEPlumber
It depends not only on the number or types of fixtures, but length of horizontal piping as well. A 4" is not always required. Building code states that you must have at least one 3" vent to roof. This maybe different for residence. Residential codes are a lot more lenient.
EEPlumber is offline
Old 06-06-2013, 04:26 AM   #4
Christoph
Christoph's Avatar
Liked 5 Times on 4 Posts
The total vent area for a building is required to equal the area of the required building drain. For example, two 2" vents combined with one 1.5" vent is equal to one 3" vent, which would be required for most houses with 3 or fewer toilets. Hard to know the size of a vent through the roof without getting a close look from above.
Christoph is offline
Old 06-06-2013, 04:49 AM   #5
chukar
Liked 19 Times on 17 Posts
You also don't need to have one vent you could have multiple vents in different locations, best way to plan it out would be a set of prints that coupled with the fact code rules depend on where the work is done. There is no simple answer.
chukar is offline
Studor vent on vent pipe above roof gquayle General Plumbing Help 4 09-13-2012 02:23 PM
Drain/Vent Question mwb31 General Plumbing Help 6 04-29-2012 02:47 AM
vent question dlangdon50 General Plumbing Help 4 05-20-2011 01:51 AM
Shower Vent Stack Question snoqdan Plumbing Building Code 3 04-05-2011 06:21 PM
another vent question bridgeboy General Plumbing Help 4 07-17-2010 10:55 AM
