Originally Posted by graysqwrl
Wow... never would've thought of that. Thanks for the help
Well considering you are ( assuming here ) a plumber, i would figure it would be easy to check out the book, as I could and could find in the appropriate section the answer to my question. otherwise if you are really unsure you should just ask your building inspector ( also an assumption that you are using one )
Being that exterior walls are subject to temperature variations and are always loadbearing I would wager that you are better off to build a plumbing wall and not to dickle around with trying to fudge pipes into the exterior wall and since i'm sure you checked your codebook, you should be able to tell us.... CAN you run piping in exterior walls in LA?
all sarcasim aside, I wouldnt properly understand Why you WOULDN't simply look in the code book.... is there a reason ?
