Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Gas piping to barbeque question.
Old 11-07-2013, 03:14 PM   #1
JohnDS
Liked 2 Times on 2 Posts
Default Gas piping to barbeque question.
Hello, i am in the middle of piping out my home with gas piping. I still need to have inspector and gas company come check out the work. I know that they do not want any open ends or capped or plugged off outlets. Rather they want all outlets going to a valve and nipple cap. My question is this:
I am piping through basement ceiling for barbeque and plan to transition to galvanized right before it goes outside.
1) Can i use a regular brass gas ball valve for outdoors like i use for the appliances inside, or do i need to use a special valve? If not, what kind of valve should i use?
2) I also want to put a gas valve before it exits the outdoors so it is tamperproof when i am away. So basically it would be two gas ball valves on the barbeque line. Is this acceptable?
JohnDS is offline
Old 11-07-2013, 06:47 PM   #2
Brass valves are fine. If you use ball valves be sure they a stamped with WOG. Which stands for water or gas.
Old 11-08-2013, 12:12 AM   #3
Liked 392 Times on 328 Posts
Likes Given: 556
Make absolutely certain that the steel pipe, even galvanized, is 100% protected from contact with any concrete, or even dirt. I have seen pictures of what a few years of contact with a corrosive concrete surface can do to galvanized pipe, and you don't want that happening to your gas pipe.
Old 11-08-2013, 02:40 PM   #4
JohnDS
Thanks guys. Any idea if the gas company would have a problem with piping outside to a barbeque? A guy who works the plumbing section at home depot(says he is a licensed plumber) said that they will fail it. Any truth to this?
Also, aside from that, i know there is a gas main shut off valve at meter, but i want my own main shutoff inside the house when pipe enters house from future gas service. Would they be ok with that?
JohnDS is offline
Old 11-14-2013, 10:55 AM   #5
plumber78
Liked 4 Times on 4 Posts
Likes Given: 6
We pipe to outside grills and fire pits on a regular basis here in Ohio. We deal with four or five different gas companies and not one of them has had an issue. I have never had an issue with a building department either.
plumber78 is offline
Old 11-14-2013, 07:57 PM   #6
klee181438
I worked for the big gas company here for some years. When they work on a meter set, they will always install an outlet cutoff for the customer. This distinguishes the customers fuel line from the gas company's. They claim this is code now, but I've never verified. They would not have a problem with the barbecue grill
Atlanta, GA Plumber
Metro Septic and Plumbing
678-873-7934
http://www.metrosepticandplumbing.com
klee181438 is offline
I have no idea what's going on with my piping. amateurplumber General Plumbing Help 1 04-07-2013 12:20 PM
Piping for sump pumps Russell General Plumbing Help 3 03-23-2012 06:39 AM
Vent piping Eng_Plumber General Plumbing Help 28 11-16-2011 12:19 AM
Need Help for Polybutylene Water Piping wangy26 General Plumbing Help 3 09-09-2011 12:19 PM
