Old 09-10-2011, 05:57 PM   #1
Default Finished flooring covering traps??
Hi all new here!
We have window wells around an older building with drains. The drains go into the basement slab with a trap. During a resent remolding job, all of the traps were covered over with carpet or tiles.
Just wondering if this is a code violation?
Thank You
blockisle9 is offline   Reply With Quote
Old 09-11-2011, 02:15 PM   #2
Master Plumber
It is in NC! I can't speak for the codes where you are, but it doesn't sound like a good idea. As the water in the traps evaporates, sewer gas will be released and probably make it's way up through the carpet or tiles.
Old 09-11-2011, 02:39 PM   #3
Originally Posted by blockisle9 View Post
Hi all new here!
Thank You
Do you mean traps or clean outs? Either one should have access, they were put there for a reason.
Old 09-11-2011, 03:37 PM   #4
They are traps. I agree, the problem is convincing the builder and or architect.
I was hoping to be able to site the aplicable code. My location is Connecticut. I know codes very from state to state but isnt there a national code?
Thanks again.
Old 09-11-2011, 04:27 PM   #5
I don't understand what the reason would be for having traps on drains for window wells. Unless they are connected to the sewer system. Which in most areas is not allowed. I would check with your building department.
Old 09-11-2011, 04:41 PM   #6
It is an existing combination system that’s why the traps.
Old 09-11-2011, 04:52 PM   #7
I don't believe combination systems are allowed. I realize Waterbury is a very old town and at one time these systems were used. But as others have stated if the water evaporates in these traps sewer gas can enter the home. At the least there should be trap primers connected to these traps.
P.S. I at one time owner property in Waterbury.
