Go Back   Plumbing Forum > General Plumbing Discussion > Plumbing Building Code
Old 03-25-2010, 01:06 AM   #1
Default Can two P traps share the same vent?
I am considering adding a shower to a bathroom with an existing tub. The tub right now is sitting on the slab and (assuming it was done to code in 1985) it has a P trap in the slab and a vent pipe in the exterior wall next to it.
I'm trying to get all of my information correct before I start tearing anything up so I was wondering if I can...
1. Remove the current P Trap
2. Split the drain line with a three way connector while not interfering with the vent in the wall
3. Put a new P Trap off of on one end of the strip for the tub and another P Trap on the other end of the split.
4. Both P Traps would vent to the single existing pipe in the wall.
All of the drain pipes are 2 in. as far as I know and it is a septic tank system (no city connection). Obviously there is going to be a lot of chipping up concrete.
My concern is the venting. Will two p traps sharing a vent pass code?
dswatuga is offline   Reply With Quote
Old 03-25-2010, 01:41 AM   #2
If I am understanding you correctly, the answer is no. What you will need to do is to is to tee into the vertical section of the vent to make a second trap arm. If height constraints won't allow this, there are other piping arrangments that will work, but are much more complicated to explain, and install.
Old 04-23-2010, 12:41 AM   #3
PlumbPr0
getplumbingsupplies's Avatar
can't you connect 2 p-traps together if there symmetrically connected..
Don't lick your fingers before noon. Get Plumbing Supplies
getplumbingsupplies is offline   Reply With Quote
Old 05-31-2010, 08:35 PM   #4
Resident
Nailer341's Avatar
What are the drains being used for?
What size is the vent?
how far are the traps from the vertical vent?
Old 06-09-2010, 10:38 PM   #5
Resident
Nailer341's Avatar
hello?----------------------
Old 06-10-2010, 12:15 AM   #6
Notice the date of the original post?
P traps, vent pipes, sharing vent pipes
