Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment > Pipe Freezing Tools
Old 07-29-2012, 03:47 AM   #1
skilbane82
Default Pipe Freezing Tools
I am looking into to buying a pipe freezing kit. I am familar with the Ridgid SF-2500 and was wondering if anyone had any experience with other brands or products and what they thought. Thanks
skilbane82 is offline
Old 07-29-2012, 03:54 AM   #2
Liked 335 Times on 273 Posts
Where is the pipe your trying to freeze? Before they had any kits we would freeze the lines with dry ice. The problem with most kits I have seen they freeze a very small area.
Old 08-04-2012, 05:20 PM   #3
Matt30
Liked 21 Times on 17 Posts
The only one i have experience with is the Ridgid one. It would plug a small area so you could put a valve in or whatever you needed. It wasnt overly heavy to lug around either.
Matt30 is offline
Old 08-05-2012, 05:16 PM   #4
Chris
Administrator
Liked 497 Times on 439 Posts
Likes Given: 42
I used the Ridgid on for years on 2" pipe and it worked pretty well. Just don't soldier to close to you r plug or you get wet. We always had to use silver soldier with oxygen and acetylene so a little warmer.
Chris is offline
Old 11-06-2013, 03:41 PM   #5
paulplumb
paulplumb's Avatar
Default Rofrost Turbo
I know this post is a little old but I swear by my Rofrost Turbo 2. I have owned one for about 5 years now. I have never had it serviced and it still works as new. I use it least once a week at it still freezes down to minus 35 degrees centigrade.
Here's a link
Emergency Plumbers Cheltenham
paulplumb is offline
Old 11-13-2013, 04:03 AM   #6
uplumb
What would be the need for freezing pipes?
uplumb is offline
Old 11-13-2013, 02:55 PM   #7
Chris
Administrator
Likes Given: 42
We sometimes need to freeze a water service in The street to repair or replace an angle meter stop before the water meter. Other than that you would either have to shut down the whole street or dig up the main and hope the corp stop is still usable.
Freezing is used anywhere you can't shut down a live line.
Chris is offline
Old 11-13-2013, 08:46 PM   #8
uplumb
Gotcha.. all that does is freeze the line to stop water flow.. that's pretty nifty..
Ever have a problem with pipes bursting?
uplumb is offline
Old 11-13-2013, 10:45 PM   #9
Chris
Administrator
Likes Given: 42
No but I have had my frozen plug blow out on me. That was a mess
Chris is offline
Old 11-15-2013, 04:37 AM   #10
chukar
Liked 19 Times on 17 Posts
Liquid nitrogen also works wonderfull from 1/2" pipe to 18" pipe.
chukar is offline
Freezing/Scalding showers Jayhawk General Plumbing Help 9 03-27-2014 12:30 AM
pex tools 220ws Plumbing Tools and Equipment 17 11-22-2012 02:26 PM
water freezing chrisaddis General Plumbing Help 1 01-10-2011 12:52 AM
Various Tools for Unclogging Drains cuseman24 Drain and Sewer Cleaning 8 11-17-2010 09:44 PM
