Go Back   Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment
Old 01-10-2011, 03:20 PM   #1
Default pex tools
what do you pros think of the pex clamp tool with stainless rings versus the
crimp tool with the copper rings..??? from Pex Supply... 50$ versus 110$ m/l
I dont want to spend 100 really...what a rip...typical...
I also saw that expander on youtube that was the shorter ratchet type,
not the long Wirsbo thing...it has the thing that pulls the ring up also on it..
who makes that,??
any links to better prices..???
220ws is offline   Reply With Quote
Old 01-11-2011, 08:40 PM   #2
yny
yny's Avatar
From what HVAC school has told us I know this system is supposed to be the best thing since sliced bread to the plumbing field.
It offers a stronger bond than soft soldering or brazing, safer (no flames need) to install, and quicker.
Also from what was said in class it's way faster to install, like night and day faster which will always lead to less cost.
Why is it so much faster, because it is flexible and can be angled with out elbows or as many connectors , and the tube comes in longer lengths than copper pipe does, it's lighter, cleaner (no flux or pipe dope) which all means it can be installed faster.
Sad it can withstand high pressure so we can use it in HVAC.
Now they have a solderless system that a 2 year old can do, it's called sharkbite. It snaps to put together and provides a tight seal, or at least is supposed to. I do not recommend it on a outside wall, or at all.
I made a mistake to allow it to be used in one of our properties as a repair, the plumber swore by it and said it would be cheaper, god knows my company is all about saving $.01 if it could be so I approved it.
Well the plumber changed his tune when we had an indoor swimming pool because of it. The tenant was not home when it broke apart, so while they were at work the water ran all day long and flooded their apartment as well as 2 other units, one on each side.
Section 608 Universal , Section 609, R 410 A cert , PM cert , IAQ cert , Green Cert
yny is offline   Reply With Quote
Old 01-11-2011, 08:55 PM   #3
yny
yny's Avatar
no sure of the name of the company, I know OCC built a bike for them but I can't think of the name of it.
Also ebay it, craigslist it and save cash.
Old 01-12-2011, 01:37 AM   #4
i got the cinch its cheaper btw never saw this parse thing that automat, turns link into video..pretty slick
Old 01-12-2011, 02:00 AM   #5
I also agree that is a pretty slick set of tools. Anyone know how much both of those tools would cost?
Old 02-17-2011, 03:57 PM   #6
Isn't the system that is demonstrated in the video the Rehau Everlock system? I like the fact that the PEX expansion fittings cause less reduction in flow than the slip on/crimp fittings. The problem seems to be that Everlock may have been removed from sale for potable household systems.
thiggy is offline   Reply With Quote
Old 04-01-2011, 01:31 AM   #7
i got the cinch and ss clamps....they worked perfectly with a fairly cheap cinch tool..
Old 05-14-2011, 11:38 PM   #8
Another-Plumber's Avatar
im looking to get into pex myself, i have been plumbing for 20 years now and only used copper, i really like the expander myself, seems so much easier to work with... but i dont know witch way ill go, the cinch is a close 2nd... its all about repipes for me, so whatever works best under a house or in the attic is what i want to use.
Old 05-15-2011, 04:02 AM   #9
Expansion Tool Kit, M12 ProPEX - Flaring And Swaging Tools - Plumbing Tools - Hand Tools : Grainger Industrial Supply
found this milwaukee expander tool, yikes.. im in love
Old 05-17-2011, 07:59 PM   #10
PEX clamp tool for $40 PEX Clamp Tool, PEX Cinch Tool for Stainless Steel PEX Clamps
plumbernyc is offline   Reply With Quote
